Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Configuration Rule Assembly Language >
About Operators
In expressions, operators define operations or relationships between operands. Operator names are case sensitive. For example,
Req(A, B)
is not the same asreq(A, B)
and will result in a syntax error.Most operator names are entirely lowercase. However, a few contain capital letters and are noted in later sections. The Rule Assembly Language has several types of operators.
- Siebel data. These operators support expressions involving data that originates elsewhere in the Siebel system.
- Boolean. These operators take logical operands and return logical results. For example:
and(
A
B
).- Comparison. These operators take numeric operands and return logical results. For example:
A, B
.- Arithmetic. These operators take numeric operands and return numeric results. They provide math operations such as addition and subtraction.
- Conditional. These operators provide conditional logical and numerical relationships, such as if-then-else.
- Special. These operators interpret their operators in a special way. Some provide access to the configuration session: for example, to signal messages or retrieve property values. They also provide binding and iteration services.
Some operators expect logical operands. Others expect numeric operands. When an operand is of a type different than the operator expects, the eConfigurator engine forces the operand to the correct type.
- When integers are used where floating point is expected, integers are converted to their double-precision floating point equivalent.
- When floating point numbers are used where integers are expected, floating point numbers are rounded to their nearest integer value.
- Numbers greater than zero are interpreted by logical operators as true.
- Numbers less than or equal to zero are interpreted by logical operators as false.
- When used as numeric operands, true is 1 and false is 0.
Product Administration Guide Published: 23 June 2003 |
