Product Administration Guide > Basic Product Administration >
Creating Product Line Names
You create product line names in Application Administration > Product Lines.
You add products to a product line by selecting a product line name in the product record. Navigate to Product Administration > Products to view product records.
To create a product line name
  1. Navigate to Application Administration > Product Lines.
  2. In Product Lines, add a new record.
  3. Fill in the following fields.
  4. Product Line. Required.
    Product Line Manager. Allows you to associate product line managers and other key personnel with the product line.
    Products. Allows you to associate products with the product line. Products can also be associated with product lines on the Products page.
    Description. Optional.
  5. Save the record.
 Published: 23 June 2003
