Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Basic Product Administration >
Obtaining a Product List Report
You can obtain a report that lists all the products in the product table. For each product, the report shows the following information:
- Product name
- Part number
- Description
- Unit of measure
- Vendor
- Product line
- Effective start date
- Effective end date
The product list displays in the Siebel Report Viewer. You can print the report or create an email attachment.
TIP: The on-screen display of the report typically lists more products on each page than the Products list. Use the report to scan through the product table.
To obtain a product list report
- Navigate to Product Administration.
- In the application View menu, select Reports.
- In the Reports dialog box, select Admin Product List.
- Click Run.
The Siebel Report Viewer appears and displays the Admin Product List report.
- Print the report or create an email attachment as desired.
Product Administration Guide Published: 23 June 2003 |
