Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Basic Product Administration >
Deleting a Product Record
Once you have created a product record, it cannot be deleted. However, you can edit all the fields in the record, including the product name.
If you change the product name, you must revise all the customizable product rules and scripts in which it appears.
Product Administration Guide Published: 23 June 2003 |
