Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Product Classes >
Defining a Class
When you define a class, it is added to the list of all available classes. The name you choose must be unique. To create a subclass, specify a parent class in the definition.
To define a class
- Navigate to Application Administration > Class Administration.
- In Classes, add a new record.
- Fill out the fields in the record and save the record.
To create a subclass, select a parent class in the Parent Class field.
The new class definition appears in the Classes list. It also appears in the Class Explorer view.
Product Administration Guide Published: 23 June 2003 |
