Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Product Classes >
Locating a Class
The Class Explorer view includes a tree display that you can expand or collapse to display the hierarchy of product classes. Use the Class Explorer to locate classes and to verify the class hierarchy after you have edited it.
To locate a class
- Navigate to Application Administration > Class Explorer.
The Class Explorer view appears. Classes display in a tree and in the Classes list.
- Click a class name in the tree to display its subclasses.
- To query for a class, click Query in the Classes list.
Results appear in both the tree and in the Classes list.
Product Administration Guide Published: 23 June 2003 |
