Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Build Customizable Products >
Selecting and Locking a Customizable Product
Before you can build or edit a customizable product, you must lock its work space. This prevents others from modifying the work space. You cannot lock versions that have already been released.
To select and lock a customizable product
- Navigate to Product Administration.
- In Products, select the desired customizable product.
- Click the Customizable Product tab.
The Customizable Product > Product Versions view appears.
- In Lock/Unlock Product, click in the Locked Flag field.
A check mark appears in the Locked Flag field. Your login ID appears in the Locked By field. The system date and time appear in the Locked Date field.
To unlock the product, click in the Locked Flag field.
Product Administration Guide Published: 23 June 2003 |
