Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Release and Manage Customizable Products >
Turning Off a Class-Product Template
When you turn off a class-product template, all its inherited features are removed from the members of its product class. The class-product's structure no longer appears in the Product UI Designer or in validation mode for members of the class. Turning off a class-product template is very similar in its effect to deleting an attribute at the class level.
UI groups are not affected when you turn off a class-product template. For members of the class, if you have added items to a UI group from a class-product template, you must manually remove them.
To turn off a class-product template
- Navigate to Product Administration.
- Select the desire class-product template.
Verify that a check mark displays in the Class Product field.
- Click the Set as Class Product/Reset button.
Verify that no check mark displays in the Class Product field.
- For every product in the same product class, open the Product UI designer and remove all the class-product template items from the UI groups.
Product Administration Guide Published: 23 June 2003 |
