Product Administration Guide > Release and Manage Customizable Products >
About Finish It!
"Finish It!" is a button that appears in configuration session selection pages. This button is active under the following conditions:
These relationships are called unsatisfied quantity relationships. In selection pages, a red asterisk displays next to the relationship name and next to the item in the relationship, indicating that the user must make a selection.
When the user clicks Finish It!, the eConfigurator engine adds items to the solution from all unsatisfied quantity relationships so that minimum cardinalities are met or exceeded. The eConfigurator engine makes arbitrary selections from these relationships. You cannot specify which products will be selected by setting the sequence of the product in the relationship.
For example, you have defined a relationship called Keyboard. This relationship has a minimum cardinality of 1 and no default product. This causes the Finish It! button to become active in configuration sessions. When the user clicks Finish It!, the eConfigurator engine adds a keyboard to the solution.
If you do not want the Finish It! button to be active during configuration sessions, specify default products for all relationships with a minimum cardinality greater than zero.
 Published: 23 June 2003
