Product Administration Guide > Mapping eConfigurator 6.x Features
to Release 7.x
Working with Linked Items
In release 7.x, you define links within the context of a specific customizable product. You do not define links in a single location and then associate the definition with a model, as in 6.x. Link definitions are added to a picklist so that you can add the definition to other customizable products. If you delete a link definition from the only customizable product in which it occurs, it is deleted from the picklist.
The things for which you can define a link, have not changed in release 7.x. You can define links on Siebel business components, the system date/time, and on the login ID of the current users.
 Published: 23 June 2003
