Product Administration Guide > Customizable Product Resources >
Editing a Resource Definition
You must select and lock a customizable product before editing a resource definition. If you change the name of a resource, the name is not changed in configuration rules where it appears.
Editing the name of a resource changes its name in the Pick Resource dialog box.
 Published: 23 June 2003
