Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Configuration Rule Template Reference >
Compound Logic and Comparison Operators
Both Compound Logic and Comparison operators test for the truth of their operands. They return a true or false rather than a quantity.
Compound Logic operators, such as AND, NOT, OR, are used to link expressions together when creating a rule. For example: (Condition A AND Condition B) requires Item C. Compound Logic operators are also called Boolean operators.
Table 31 presents the Compound Logic operators you can use with rule templates.
Comparison operators compare their operands and return a true or false. In the following rule, when the quantity of item A is less than item B (when the comparison is true), then item C is required.
(Item A < Item B) requires C
If you specify an item as an operand in a comparison, the quantity of the item in the solution is used to make the comparison. If you specify an expression as an operand, the expression must resolve to a number.
If you specify an expression that resolves to true or false, then true is assigned the value 1 and false is assigned the value 0.
Table 32 presents the Comparison operators you can use with rule templates.
When you are building a rule, you can compound the comparison operators. For example, you could build the following expression:
(A>B>C>D)
This expression is equivalent to the following expression:
A>B AND A>C AND A>D
Product Administration Guide Published: 23 June 2003 |
