Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Customizable Product Scripts >
Reviewing the Script Log
If a method within a script fails or the script contains syntax errors, you can obtain valuable diagnostic information by reviewing the script log.
To review the script log
- Navigate to \log\cfgscript.log. It is located in the Siebel installation directory.
- Open the file with a text editor.
- Locate the entries for the date and time the script ran.
Product Administration Guide Published: 23 June 2003 |
