Product Administration Guide > Technical Reference >
eConfigurator API
This section summarizes the APIs available to the Siebel eConfigurator, version 7.5.x and focuses on a segment of those APIs.
This section introduces advanced users to APIs. It assumes that you know Siebel eConfigurator and Siebel server architecture. Implementing the APIs described in this section also requires proficiency in Siebel EAI and Siebel Object Interfaces.
To use these APIs, the user should be familiar with the following:
Available APIs
There are three main groups of APIs used for accessing Siebel eConfigurator. These APIs are supported by the Complex Object Instance Service.
 Published: 23 June 2003
