Bookshelf Home | Contents | Index | Search | PDF |
Product Administration Guide > Technical Reference >
Enabling Auto Match
When a new version of a customizable product is released, Auto Match adjusts the configuration of the product in a quote, asset, or order to reflect the changes. Auto Match is disabled by default.
For Web Client users, you turn Auto Match on by setting its server parameter to TRUE. Table 49 shows the Auto Match server parameter.
For Dedicated Web Client users (also called mobile client users), add the following entries to the configuration file used to start the application, for example Siebel.cfg.
;; This section will be read for mobile clients only
[InfraObjMgr]
eProdCfgAutoMatchInstance=TRUE
Product Administration Guide Published: 23 June 2003 |
