Bookshelf Home | Contents | Index | Search | PDF |
Upgrade Guide for UNIX > Postupgrade Tasks > Postupgrade Tasks for All Environments >
Testing the Upgraded Configuration
CAUTION: This procedure only applies to development environment upgrades. For production environment upgrades, skip this procedure and proceed to Validating Dock Objects and Rule Definitions.
You must test the upgraded configuration thoroughly to make sure that all functionality works as expected. You need to execute your full development or acceptance test plan, including at least one synchronization session from a mobile client, before proceeding to upgrade your production environment.
If you make further changes to your customized configuration, remember to re-export the repository to the
custrep.dat
file before running the production environment upgrade.NOTE: Save the log files generated during the repository upgrade and schema upgrade. Locate the custrep.dat file in the
DBSRVR_ROOT\COMMON
subdirectory. Save thecustrep.dat
file for your production upgrade.
Upgrade Guide for UNIX Published: 20 October 2003 |
