Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless > Configuring with Siebel Tools >
Supported Methods
The Method Invoked specifies the method invoked by a form control when a button is clicked, for controls where the HTML Type is set to Link. Methods that can be referenced in the Method Invoked column for Siebel Wireless form controls are shown in Table 9.
Table 9.  Supported Methods
Method
Purpose
Comments
Write record
Commit New or Edit Record
For Reroute class, use control user property: View ="View name to reroute to" (optional)
UndoRecord
Cancel new, edit or delete record
PickRecord
Pick a record from Pick Applet
Use control user property:
FieldType ="Control/List item Name" FieldName = "Field Name"
OrderAllParts
Create auto order for orderable recommended parts
OnSubmitHTML
Submit Correspondence
NewRecord
Open new record template to create an new record
NewQuery
Open query template for a new search
GotoView
Navigate from a control link to a specified view
View ="View name to navigate to"
GotoPrevious
Used in Calendar to go to previous set of appointments
GotoNext
Used in Calendar to go to next set of appointments
GotoPage
Page = "Page to navigate to"
Siebel Wireless applications only use SWLS Start Page (Main Menu Page)
ExecuteQuery
Execute search
EditRecord
Open edit template to edit a field
DeleteRecord
Delete current record
For reroute class, use control user property View = "View name to reroute to" (Optional)
CommitPartMvmtClient
Commit a service activity part tracker
 Published: 18 April 2003
