Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless >
Supporting Wireless Requests with Multiple Markup Languages
If your users are using different browsers, you may need to configure Siebel Wireless applications to handle multiple markup languages. Siebel Wireless applications can be configured to handle all wireless requests through the XML Web Interface, or to handle only certain wireless requests through the XML Web Interface and to handle others through the WML Interface.
To make sure that Wireless requests are handled as desired, first determine whether Siebel software will need to support:
If Siebel Wireless will need to handle requests for WML browsers only or for both WML and non-WML browsers (the first two cases above), the following configuration must be performed.
To configure for WML and non-WML browsers
  1. Make sure that the MarkupLanguage parameter in the SWE section of relevant Siebel Wireless server configuration files is set as follows:
  2. [SWE]
    MarkupLanguage = WML
    NOTE:  WML is the default value for this parameter when Siebel software is installed.
  3. Create the following Web Browser entries using the Web Browser Administration screen in the Siebel Web Client for each wireless browser for which requests will be handled by the XML Web Interface:
  4. Create the following Web browser entries using the Web Browser Administration capability in the Siebel Web Client for each wireless browser for which requests will be handled by the WML Interface:
User agents must be defined for both WML and non-WML browsers to make sure that the correct interface is applied.
If MarkupLanguage is set to WML as described above, any wireless request for which no user agent is recognized is treated as an XML request. Additionally, any wireless request from a user agent which has HTML defined as its default markup is treated as an XML request.
See Siebel Web Client Administration Guide for additional details on defining Web browsers and user agents using Web Browser Administration.
If Siebel Wireless will need to handle requests only through the XML Web Interface, the following configuration must be performed:
This process of determining a markup language for a particular request described above can be overridden by setting the SWESetMarkup parameter for inbound wireless requests. Valid values for this SWESetMarkup parameter are XML or HTML (not WML).
For example, this parameter can be set as follows to force a particular wireless request to be rendered in XML, regardless of the MarkupLanguage defined in the wireless configuration file or the DefaultMarkup defined for that browser:
SWESetMarkup="XML"
 Published: 18 April 2003
