Siebel Wireless Administration Guide For Financial Services > Configuring Siebel Wireless >
Configuring Main Menu Layout and Record Order
You can determine which applications are available for customization by the user, and you can establish the fields available for the user to sort on. To do so, you modify the .cfg file associated with the application containing the Mobile Device screen, the screen used for customization by the user.
The user establishes preferences by means of the Main Menu Layout tab and the Record Order tab on the Mobile Devices screen in the Siebel Web client. For information about how the user establishes main menu and record order preferences, see Personalizing Your Wireless Device.
 Published: 18 April 2003
