Bookshelf Home | Contents | Index | Search | PDF |
Siebel Wireless Administration Guide For Financial Services > Using Siebel Wireless > Entering Text >
Entering Dates
The screen label indicates how to enter dates. For American English versions, for example:
- When entering a date, use the MMDDYY format.
- Slashes are inserted automatically as you enter text when using some wireless browsers. For example, to specify April 18, 2000, enter 041800 and you will see 04/18/00 on the screen. These slashes are generally not required to enter data into Siebel Wireless.
- You must use all six digits of the MMDDYY format. For example, entering
3/5/73 (rather than 03/05/73 or 030573) produces an error.
Siebel Wireless Administration Guide For Financial Services Published: 18 April 2003 |
