CREATE PACKAGE BODY Statement
The CREATE PACKAGE BODY statement creates or replaces the body of a stored package, which is an encapsulated collection of related procedures, stored functions, and other program objects stored as a unit in the database. The package body defines these objects. The package specification, defined in an earlier CREATE PACKAGE statement, declares these objects.
Packages are an alternative to creating procedures and functions as standalone schema objects.
Topics
Prerequisites
To create or replace a package in your schema, you must have the CREATE PROCEDURE system privilege. To create or replace a package in another user's schema, you must have the CREATE ANY PROCEDURE system privilege. In both cases, the package body must be created in the same schema as the package.
To embed a CREATE PACKAGE BODY statement inside an the database precompiler program, you must terminate the statement with the keyword END-EXEC followed by the embedded SQL statement terminator for the specific language.
Semantics
OR REPLACE
Re-creates the package body if it exists, and recompiles it.
Users who were granted privileges on the package body before it was redefined can still access the package without being regranted the privileges.
schema
Name of the schema containing the package. Default: your schema.
package_name
Name of the package to be created.
declare_section
Has a definition for every cursor and subprogram declaration in the package specification. The headings of corresponding subprogram declarations and definitions must match word for word, except for white space.
Can also declare and define private items that can be referenced only from inside the package.
Restriction on declare_section The AUTONOMOUS_TRANSACTION pragma cannot appear here.
initialize_section
Initializes variables and does any other one-time setup steps.
Examples
Creating a Package Body: Example This statement creates the body of the emp_mgmt package created in "Creating a Package: Example".
CREATE OR REPLACE PACKAGE BODY emp_mgmt AS
   tot_emps NUMBER;
   tot_depts NUMBER;
FUNCTION hire
   (last_name VARCHAR2, job_id VARCHAR2,
    manager_id NUMBER, salary NUMBER,
    commission_pct NUMBER, department_id NUMBER)
   RETURN NUMBER IS new_empno NUMBER;
BEGIN
   SELECT employees_seq.NEXTVAL
      INTO new_empno
      FROM DUAL;
   INSERT INTO employees
      VALUES (new_empno, 'First', 'Last','first.example@oracle.com',
              '(415)555-0100','18-JUN-02','IT_PROG',90000000,00,
              100,110);
      tot_emps := tot_emps + 1;
   RETURN(new_empno);
END;
FUNCTION create_dept(department_id NUMBER, location_id NUMBER)
   RETURN NUMBER IS
      new_deptno NUMBER;
   BEGIN
      SELECT departments_seq.NEXTVAL
         INTO new_deptno
         FROM dual;
      INSERT INTO departments
         VALUES (new_deptno, 'department name', 100, 1700);
      tot_depts := tot_depts + 1;
      RETURN(new_deptno);
   END;
PROCEDURE remove_emp (employee_id NUMBER) IS
   BEGIN
      DELETE FROM employees
      WHERE employees.employee_id = remove_emp.employee_id;
      tot_emps := tot_emps - 1;
   END;
PROCEDURE remove_dept(department_id NUMBER) IS
   BEGIN
      DELETE FROM departments
      WHERE departments.department_id = remove_dept.department_id;
      tot_depts := tot_depts - 1;
      SELECT COUNT(*) INTO tot_emps FROM employees;
   END;
PROCEDURE increase_sal(employee_id NUMBER, salary_incr NUMBER) IS
   curr_sal NUMBER;
   BEGIN
      SELECT salary INTO curr_sal FROM employees
      WHERE employees.employee_id = increase_sal.employee_id;
      IF curr_sal IS NULL
         THEN RAISE no_sal;
      ELSE
         UPDATE employees
         SET salary = salary + salary_incr
         WHERE employee_id = employee_id;
      END IF;
   END;
PROCEDURE increase_comm(employee_id NUMBER, comm_incr NUMBER) IS
   curr_comm NUMBER;
   BEGIN
      SELECT commission_pct
      INTO curr_comm
      FROM employees
      WHERE employees.employee_id = increase_comm.employee_id;
      IF curr_comm IS NULL
         THEN RAISE no_comm;
      ELSE
         UPDATE employees
         SET commission_pct = commission_pct + comm_incr;
      END IF;
   END;
END emp_mgmt;
The package body defines the public program objects declared in the package specification:
  • The functions hire and create_dept
  • The procedures remove_emp, remove_dept, increase_sal, and increase_comm
These objects are declared in the package specification, so they can be called by application programs, procedures, and functions outside the package. For example, if you have access to the package, you can create a procedure increase_all_comms separate from the emp_mgmt package that invokes the increase_comm procedure.
These objects are defined in the package body, so you can change their definitions without causing the database to invalidate dependent schema objects. For example, if you subsequently change the definition of hire, then the database need not recompile increase_all_comms before running it.
The package body in this example also declares private program objects, the variables tot_emps and tot_depts. These objects are declared in the package body rather than the package specification, so they are accessible to other objects in the package, but they are not accessible outside the package. For example, you cannot develop an application that explicitly changes the value of the variable tot_depts. However, the function create_dept is part of the package, so create_dept can change the value of tot_depts.
