Oracle® Beehive Installation Guide Release 1 (1.4) for Microsoft Windows (32-Bit) Part Number E13792-02 |
View PDF |
These steps describe how to upgrade the following products:
Oracle Beehive Release 1 (1.3) to Release 1 (1.4.1)
Oracle Beehive Provisioning Application version 1.3 to Oracle Beehive Provisioning Application version 1.4.1
Oracle Beehive for DMZ version 1.3 to version 1.4.1
Oracle Beehive Integration for Zimbra version 1.3 to 1.4.1
Upgrade Oracle Beehive and any other Oracle Beehive application tiers before upgrading any other Oracle Beehive products.To upgrade an Oracle Beehive Release 1 (1.3) deployment to Release 1 (1.4.1), upgrade the following Oracle Beehive products in the indicated order:
Oracle Beehive Release 1 (1.3) application tiers to Release 1 (1.4.1).
You must shutdown all Oracle Beehive Release 1 (1.3) application tiers before upgrading them.
Ensure that the upgrade process has started your newly upgraded Oracle Beehive application tiers before proceeding to upgrade other Oracle Beehive products.
Refer to "Upgrading Multiple Oracle Beehive Application Tiers" if you are upgrading more than one Oracle Beehive application tier.
Any standalone Oracle Beehive Integration for Zimbra, Oracle Beehive Provisioning Application, or Oracle Collaboration Coexistence Gateway (Microsoft Windows only) Release 1 (1.3) instances to Release 1 (1.4.1)
Any Oracle Beehive Release 1 (1.3) DMZ instances to Release 1 (1.4.1)
You must shutdown all Oracle Beehive Release 1 (1.3) DMZ instances before upgrading them.
Ensure that the upgrade process has started your newly upgraded Oracle Beehive DMZ instances before proceeding to upgrade other Oracle Beehive products.
Any Oracle Beekeeper Release 1 (1.3) instances to Release 1 (1.4.1)
Start the Oracle Beehive Install Wizard.
In the Select Product Type screen, select the Oracle Beehive product you want to upgrade.
After the Select Installation Type screen, the Oracle Beehive Installation Wizard will automatically detect if you have any existing Oracle Beehive products on the computer from which you started the Oracle Beehive Install Wizard.
If the Install Wizard detects any existing Oracle Beehive products that can be upgraded, you will see the screen Upgrade Existing Home. Depending on the product you want to upgrade, refer to one of the following sections:
After upgrading your deployment to Oracle Beehive Release 1 (1.4.1), apply a deployment template to it. Refer to "Applying Deployment Template after Upgrade" for more information.Note:
In Microsoft Windows, ensure the following before proceeding with upgrading Oracle Beehive:Ensure that there is only one window session (desktop) is present. Close all other window sessions. Many window sessions can be opened with Windows Remote Desktop or Virtual Network Computing (VNC) applications.
Ensure that you have closed all Windows Explorer windows, unnecessary applications, and command prompts. These may interfere with the upgrade process, especially if Windows Explorer or a command prompt is pointing to the directory <Oracle home>
\j2ee
If the Oracle Beehive Wizard detects any existing Oracle Beehive Release 1 (1.3) instances on the computer from which you started the wizard, the following screens will appear:
You must shutdown all Oracle Beehive Release 1 (1.3) application tiers before upgrading them.Ensure that the upgrade process has started your newly upgraded Oracle Beehive application tiers before proceeding to upgrade other Oracle Beehive products.
Specify if you want to upgrade the product you selected in Select Product Type.
If the installer detected any existing Oracle Beehive Release 1 (1.3) instances, specify Yes to upgrade one of those instances to Oracle Beehive Release 1 (1.4.1).
If you specify No, the Install Wizard will proceed to perform a standard installation of Oracle Beehive Release 1 (1.4.1).
Select from the drop down box the complete path of the Oracle Beehive instance you want to upgrade.
The drop down box will only contain Oracle Beehive home paths with the following characteristics:
Contains an instance of Oracle Beehive Release 1 (1.3)
Is registered in the central Oracle Universal Installer inventory of the computer from which you started the Install Wizard.
Shut down all instances listed in the table. Once you have shut the instances down, click the Rescan button to verify that all managed instances are down.
You must manually verify that all unmanaged instances (listed in red) are shutdown. Unmanaged instances include Oracle Beekeeper instances and Oracle Beehive DMZ instances. Currently, Oracle Beehive cannot determine whether an unmanaged instance has been fully shutdown (regardless of whether the instance is on the same machine as the pending upgrade or not). Once you have shutdown all unmanaged instances, select Unmanaged Instances Verified to continue the upgrade.
Specify the password of the SYS schema for the database with the specified service name.
The Upgrade Summary screen presents a summary of the options you have specified so far:
Space Requirements: The disk space required to upgrade the product. The space requirement appears in a different color if the disk space available is less than what is required.
Notes:
The space requirements shown on this screen do not include the space required in the target database.The space requirements shown on this screen also might differ slightly from the actual space the component occupies on the installation disk. This is because of the differences in the disk configurations. For example, the space required on one hard drive might differ from the space required on another hard drive that uses different block size or that is managed by a different file system.
Inventory Location: The location of the oraInventory
directory where all the installation information about your product will be stored.
Product: The name of the product you are upgrading, Oracle Beehive Release 1
Interview Details: The details of your inputs for the other screens, such as:
Home Details: The location of the Oracle home that you are upgrading.
Database Information for Upgrade: The host name, port, service name, administrator user name, and password of the existing Oracle Database instance that will be used by this upgrade process.
Enterprise Definition Information: The detailed enterprise site information that identifies this upgrade.
Schema Password: The masked password for the Oracle database schema that you specified.
When you have reviewed your inputs, click Upgrade to continue.
Use this screen to monitor the upgrade process. Click Show Details to see the details in the description box that appears.
This screen displays the configuration assistants that the Oracle Beehive Install Wizard runs to upgrade Oracle Beehive.
The Oracle Beehive Install Wizard performs the following configuration assistants:
Upgrading Central Inventory: Upgrades the product metadata to the proper version (1.4.1)
Applying oneoff patches: Applies patches specific to this release
Upgrading Beehive Schemas: Upgrades the Oracle Beehive schemas within the Oracle Beehive database
Upgrading Beehive Midtier: Upgrades the Oracle Beehive application tier configuration
This screen indicates if the upgrade of Oracle Beehive is successful.
If the Oracle Beehive Wizard detects that Oracle Beehive Provisioning Application version 1.3 is installed on the computer from which you started the wizard, the following screens will appear:
If the installer detected that Oracle Beehive Provisioning Application version 1.3 is installed in your computer, specify Yes to upgrade it to version 1.4.1.
If you specify No, the Install Wizard will proceed to install Oracle Beehive Provisioning Application version 1.4.1 in a new Oracle home.
Select from the drop down box the complete path of the Oracle Beehive product you want to upgrade.
Contains Oracle Beehive Provisioning Application version 1.3
Notes:
Product: The name of the product you are upgrading, Oracle Beehive Provisioning Application
This screen indicates if the upgrade of Oracle Beehive Provisioning Application is successful.
After upgrading Oracle Beehive Provisioning Application to version 1.4.1, a component named after the version number to which you upgraded will be added to the Oracle Enterprise Manager Grid Control software library.If the Oracle Beehive Wizard detects that Oracle Beehive for DMZ version 1.3 is installed on the computer from which you started the wizard, the following screens will appear:
You must shutdown all Oracle Beehive Release 1 (1.3) DMZ instances before upgrading them.Ensure that the upgrade process has started your newly upgraded Oracle Beehive DMZ instances before proceeding to upgrade other Oracle Beehive products.
If the installer detected that Oracle Beehive for DMZ version 1.3 is installed in your computer, specify Yes to upgrade it to version 1.4.1.
If you specify No, the Install Wizard will proceed to install Oracle Beehive for DMZ version 1.4.1 in a new Oracle home.
Contains Oracle Beehive for DMZ version 1.3
Notes:
Product: The name of the product you are upgrading, Oracle Beehive for DMZ
This screen displays the configuration assistants that the Oracle Beehive Install Wizard runs to upgrade Oracle Beehive for DMZ.
This screen indicates if the upgrade of Oracle Beehive for DMZ is successful.
If the Oracle Beehive Wizard detects that Oracle Beehive Integration for Zimbra version 1.3 is installed on the computer from which you started the wizard, the following screens will appear:
If the installer detected that Oracle Beehive Integration for Zimbra version 1.3 is installed in your computer, specify Yes to upgrade it to version 1.4.1.
If you specify No, the Install Wizard will proceed to install Oracle Beehive Integration for Zimbra version 1.4.1 in a new Oracle home.
Contains Oracle Beehive Integration for Zimbra version 1.3
Notes:
Product: The name of the product you are upgrading, Oracle Beehive Integration for Zimbra
This screen displays the configuration assistants that the Oracle Beehive Install Wizard runs to upgrade Oracle Beehive Integration for Zimbra
Upgrading Oracle Beehive Integration for Zimbra Schemas: Upgrades the Oracle Beehive Integration for Zimbra schemas within the Oracle Beehive database
Upgrading Oracle Beehive Integration for Zimbra Midtier: Upgrades the Oracle Beehive Integration for Zimbra application tier configuration
This screen indicates if the upgrade of Oracle Beehive Integration for Zimbra is successful.
