Siebel Business Process Framework: Workflow Guide > Using Predefined Workflow Policies > Types of Predefined Workflow Policy Programs > Workflow Policy Program That Sends a PageTable 45 describes arguments and values for the Send Page workflow policy program type. If you choose a Send Page type of workflow policy program in the Actions view in the Siebel client, such as Send SR Page, then Siebel CRM displays the Send Page Arguments form and the Recipients list. The Send Page Arguments form allows you to define a template that Siebel CRM uses to create the message it sends to the recipient that you add in the Recipients list.
Using Numeric PagingNumeric paging is inherently not reliable because of insufficient computer protocols that exist to send a numeric page. If Siebel CRM must send a numeric page, then you can use the Pager Pin field in the employee table to control the delay that occurs between dialing the paging phone number and sending the numeric message. You can add commas to the Pager Pin field. Two commas is equal to approximately a one second delay. It is recommended that you avoid using numeric paging in a Siebel CRM application that is mission critical. |
Siebel Business Process Framework: Workflow Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
