Siebel Hospitality Guide > Generating Event Checks > Process of Generating Event Checks > Adding, Changing, and Recalculating Event Check Line ItemsTo add, change, and recalculate event check line items, follow the procedures in this topic. This task is a step in Process of Generating Event Checks. Adding or Changing Line Items in an Event CheckEvent managers generate event checks when they believe that all details about the event are included in the order. However, after the event check is generated, the event manager might notice that a product that was used at the event is not included the order. In this case, the event manager can add extra line items for the product to the event check. NOTE: Siebel Hospitality keeps the quote, order, and event check in sync. Consequently, if you add or modify an item in an event check, then the same modification occurs automatically in the associated order and quote. To add or change line items in an event check
Recalculating Taxes and Service Charges for an Event CheckAfter the event manager adds line items or modifies existing line items, the Recalculate flag for the event check is automatically selected. Consequently, the event manager must automatically recalculate the taxes and service charges for the event check. |
Siebel Hospitality Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
