Siebel Product Administration Guide > Products with Attributes > Process of Creating Products with Attributes >
Associating Attributes with a Product
To associate attributes with a product, you assign the product to a product class. The product inherits all the attributes of the product class or subclass to which it is assigned.
This task is a step in Process of Creating Products with Attributes.
NOTE:  Before you associate the product with a product class, you must create the product, as described in Basic Product Administration.
To associate a product with a product class
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Versions list, in the record for the Work Space version, in the Product Class field, select the product class.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
