Siebel Product Administration Guide > Products with Attributes > About Managing Product Classes > Deleting Product Class RecordsYou cannot delete a product class record. If you no longer want to use the product class, you can deactivate all versions rather than deleting the product class. Before doing this, verify that the product class is not used for defining any active products. If you have a large number of inactive versions for a given product class, you can delete the versions using the CleanupSingleObject method of the ISS Authoring Import Export Service. For more information, see Siebel Order Management Guide. |
Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
