Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
GetRootPath Method
This method returns the path of the complex object instance root.
Input Arguments
  • ObjId. The unique identifier of the complex object header (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
The root path is returned as a property of the output property set, as follows:
< Path="value" />
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
