Siebel Product Administration Guide > Configurator Workflow and Method Reference > Siebel Configurator Methods Reference > LoadInstance MethodLoadInstance method is invoked on the Cfg UI Service to display Customize UI. It calls LoadInstance on Complex Object Instance Service to initialize the instance service with CxObj created in the LoadEAI step. The instance service also validates the CxObj against the product definition from Cfg Broker. It also does Promotion validation and Eligibility & Compatibility violation checks. The session with the Rule engine evaluator (ILOG) is also initialized if needed. The UI Service gets the updated CxObj representation from Instance Service and displays the UI based on the product model definition. This method is part of the Cfg Web UI Service Loader business service. It must not be confused with LoadInstance Method, which is part of Complex Object Instance business service. NOTE: The LoadInstance method cannot be used without first calling the LoadEAI method, which is described in the Copy Service reference in Siebel Order Management Infrastructure Guide. SyntaxLoadInstance <inputArgs>, <outputArgs> Input ArgumentsOutput ArgumentsUsageLoadInstance method is invoked on the Cfg UI Service to display the Customize UI. It calls LoadInstance on Complex Object Instance Service to initialize the instance service with CxObj created in the LoadEAI step. Invoked FromBrowser Script, COM Data Control, COM Data Server, Server Script, Java Data Bean, Mobile/Developer Web Client Automation Server |
Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
