Siebel Product Administration Guide > Releasing Products and Other Versioned Objects >
Releasing Multiple Products Using Workspace Projects
The instructions in earlier topics of this chapter describe how to release versioned items one at a time. You can also release a number of versioned items at the same time by using the Workspace Projects view.
If you are modifying and releasing products one at a time, use the methods described in the earlier topics of this chapter.
If you are modifying many products and other versioned items as part of one project and you want to release them all at one time, use the method described in this topic.
To release multiple products simultaneously
  1. Navigate to the Administration - Product screen, Workspace Projects, and then the Contents view.
  2. In the Contents list, select all the items you want to release.
  3. Click Release New Version.
To release all locked products
  2. Make sure all objects in the Contents view are locked.
  3. In the Contents view, click Release All.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
