Siebel Product Administration Guide > Multilingual Translations for Product Data >
Translating the Product Description
Use these procedures to translate the product description.
To translate the product description
  1. Navigate to the Administration - Product screen, then the Products view.
  2. Select a product whose description you want to translate.
  3. Click the Translations view tab.
  4. Add a new record to the Translations list and complete the necessary fields, described in the following table.
    Field
    Comments
    Language
    Displays the name of the language after you select the code.
    Code
    Select a language code.
    Description
    Enter the translation of the description.
To translate the product description of customizable products
  1. Navigate to the Administration - Product screen, then the Product Definitions view.
  2. In the Product Definitions list, select a customizable product whose description you want to translate.
  3. In the Versions list, click the name of the Work Space version.
  4. Click the Display Names view tab.
  5. Add a new record to the Display Names list and complete the necessary fields, described in the following table.
    Field
    Comments
    Display Name
    Enter the translation of the name.
    Language
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
