Siebel Product Administration Guide > Configuration Resources > Creating Configuration ResourcesWhen you create a resource, it is added to a dialog box. You can copy this resource definition to other customizable products and edit the definition as needed. In turn, the edited definition is added to the dialog box. When you remove a resource from a customizable product, it is removed from the dialog box. All resources have the data type number. They can have only numeric, integer, or floating point values.
Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
