Siebel Product Administration Guide > Configuration Constraint Template Reference > Procedural Condition Templates > Set Procedural Conditional Variable TemplateThe Set Procedural Conditional Variable template has the form: [Item or condition] sets Procedural condition variable value to true This template defines a variable on the product instance. This variable's name is the rule name, and its value is evaluated after each user click. The variable can be retrieved from the Siebel Configurator service using a script and can be used to control the application behavior dynamically. Excluding Values in the Administration - Product ScreenYou can specify in the Administration - Product screen that certain values are excluded based on the expression variables defined by Set Procedural Conditional Variable rules. You can do this using the property, CondExcl=exprVarName. The attribute values or products in the domain with this property are shown as excluded when exprVarName evaluates to true. To exclude values based on Set Procedural Condition Variable rules |
Siebel Product Administration Guide | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
