Siebel Product Administration Guide > Siebel Configurator Scripts > About Managing Siebel Configurator Scripts >
Editing Siebel Configurator Scripts
You can edit scripts by selecting the script in the Scripts view. If you edit declaration scripts, verify that the changes do not adversely affect event scripts.
To edit a script
  1. Navigate to the Administration - Product screen.
  2. Select and lock the desired product or product class.
  3. Navigate to the Scripts view for the Work Space version.
  4. Highlight the script you want to edit.
    The script displays in Script Definition form, located below the list of scripts.
  5. In the Script Definition form, edit the script.
  6. When you have finished editing the script, click Check Syntax.
    If there are errors, they will display at the top of the Customizable Product Scripts form. Correct any errors before saving the script.
  7. In the Script Definition form, click Save.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
