Siebel Product Administration Guide > Smart Part Numbers for Products with Attributes >
Editing a Predefined Generation Method
You can edit a predefined generation method in several ways:
  • Edit the name of the generation method
  • Delete the generation method
  • Edit the part numbers in a generation method's part number matrix
  • Add or delete records in a generation method's part number matrix
  • Regenerate the part number matrix, using different attributes
If you edit the name of a generation method or delete the method, the change is reflected in all product records to which the method is assigned. For example, you delete the generation method Predefined1. All product records that have Predefined1 as the Part Number Method, no longer have an assigned generation method.
If you edit the part number matrix for a generation method, the changes become effective immediately. The next time the product is added to quote, order, and so on, the revised part number scheme will be used. The part numbers assigned to products are not changed. You can update the part number by reselecting the product attributes.
If you add or remove attributes defined on a class or change attribute values, these changes are not propagated to the generation method. You must manually update the method. To do this, see Updating a Generation Method with Attribute Changes.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
