Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Configuring the Object Broker
If you modify the assignment of Cfg UI Field properties on the fields of the Cfg ISS Prod Def business component, you must do the following:
  • After you have made the changes, manually clean the file system's ISS_OBrkCache folder, as described in Delete Contents of ISS_OBrkCache Directory.
  • Run all installations of Siebel applications that use the same file system from the SRF where you have made the changes.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
