Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Operating System Environment Variables Used with Siebel Configurator
When you are setting up Siebel Configurator, it can be useful to set the operating system environment variables described in Table 48.
Table 48. Operating System Environment Variables Used with Siebel Configurator
Variable Name
Description
CFG_BROKER_FS
Additional file system directory used by the Broker to support multiple file system locations. The value of this variable is appended to the list of possible locations.
When remote Siebel Configurator is used, set this variable on both the operating system of the Application Object Manager and the operating system of the remote Siebel Configurator. It is used by the object broker and object administration.
CFG_IGNORE_MISSING_ELEMENTS
Flag to determine whether to ignore the overwritten attributes with the missing base definitions. The possible values are TRUE or FALSE.
When remote Siebel Configurator is used, set this variable on the operating system of the remote Siebel Configurator. It is used by the factory.
CFG_PASSWORD
Login password used in remote service.
When remote Siebel Configurator is used, set this variable on the operating system of the Application Object Manager. It is used by the remote proxy.
CFG_USERNAME
Login user name used in remote service.
PRESERVE_ENGINE_AND_USER_PICKS
Flag to determine whether the application preserves engine and user pick. The possible values are Y or N.
When remote Siebel Configurator is used, set this variable on the operating system of the remote Siebel Configurator. It is used by the instance service.
SIEBEL_ENFORCE_REQUIRED_ATTRIBUTES
Flag to determine whether the application enforces the required attributes. The possible values are Y or N.
When remote Siebel Configurator is used, set this variable on both the operating system of the Application Object Manager and the operating system of the remote Siebel Configurator. It is used by the engine and the user interface.
SKIP_HIDDEN_AND_NOT_REQUIRED_ATTRIBUTES
Flag to determine whether the application skips the attributes that are hidden and not required. The possible values are Y or N.
When remote Siebel Configurator is used, set this variable on the operating system of the remote Siebel Configurator. It is used by the instance service and session.
SEBL_CFG_SEARCH_LIMIT
The number that determines the search limit. Used to limit the counter for the number of failed searches. Set on all application servers.
By setting a very high number, you tell the engine not to exit the solve operation. In some cases, if the engine can not find a solution after a reasonable number of iterations, it displays an error message, but if this variable has a high value, it keeps trying, which can slow the response time to unacceptable levels.
VOD_PROFILER_ON
Flag to determine whether to collect the statistical data on instrumented functions. The possible values are TRUE or FALSE.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
