Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Enabling Auto Match
When a new version of a customizable product is released, Auto Match adjusts the configuration of the product in a quote, asset, or order to reflect the changes. Auto Match is disabled by default.
For Web Client users, you turn Auto Match on by setting its server parameter to TRUE. Table 46 shows the Auto Match server parameter.
Table 46. Server Parameter for Auto Match
Parameter Name
Display Name
Data Type
Default Value
Description
eProdCfgAutoMatchInstance
Product Configurator - auto match quote on reconfigure.
Boolean
FALSE
When set to FALSE, Auto Match is turned off. When set to TRUE, Auto Match is turned on.
For Developer Web Client users (also called mobile client users), add the following entries to the configuration file used to start the application, for example Siebel.cfg.
;; This section will be read for mobile clients only
[InfraObjMgr]
eProdCfgAutoMatchInstance=TRUE
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
