Siebel Remote and Replication Manager Administration Guide > Reference Materials for Siebel Remote >
Parameters of the Regional Database Initialization Program
Table 67 lists some of the parameters and corresponding flags that are available for the Srvrinit utility.
Table 67. Parameters and Command Line Flag for the Srvrinit Utility
Parameter
Flag
Description
Required
16K Table Space
ks
For DB2/UDB installations only, provide the name of the appropriate 16K Table space. For more information, see the Siebel Installation Guide for the operating system you are using.
No
32 K Table Space
ls
For DB2 installations only, provide the name of the appropriate 32K Table space. For more information, see the Siebel Installation Guide for the operating system you are using.
No
File System
filesystem
File system directory on the regional node.
The file system parameter must reference the parent directory of the att directory. The Srvrinit utility automatically copies the files to the att directory.
Yes
Help
help
Help for usage.
No
Index Space
is
For DB2/UDB and Oracle installations only. Space on the regional database where indexes are created.
No
Initialize on new database
init
Specifies if the regional database is empty or not:
  • Y. Indicate the initialization of the Siebel Server of a regional node on a new database.
  • N. Indicate an upgrade of the existing regional database with a new database extract.
The default value is N.
An old transaction might be invalid for the new schema and can cause failure. You must set this parameter to Y during a major upgrade.
No
(Not applicable.)
comm
Communication parameters for modem connections.
No
(Not applicable.)
l
Language code. The default value is enu.
No
(Not applicable.)
v
Verbose mode, which you can set to Y or N. The default value is N.
No
ODBC Data Source
d
Name of ODBC data source to connect to the regional node.
Yes
Parent AppServer Name
dockconnstring
Name of the Siebel Server at the parent node where Siebel Remote performs the server database extract.
Yes
Regional Server Name
n
Name of the regional node.
Yes
Repository Name
reposname
Name of repository, which is usually Siebel Repository.
Yes
Run in Parallel/Number of Threads
para
Specifies to run srvrinit in parallel. Specifies the number of threads to run.
No
Schema Qualifier
sq
For DB2/390 and AS/400 environments only, the name that the Srvrinit utility uses to qualify database objects it creates that the Siebel application requires.
Yes
Server Root Directory
homedir
Root directory of the Siebel Server on the Regional node. In this document, SIEBEL_ROOT is the root directory where you install the Siebel Server.
Yes
Table Grouping File
tg
For DB2/390 installations only. Full path to the storage control file, which is a file that contains declarations for database objects.
Yes
Table Owner Password/Privileged User Password
tp
Password of the tableowner on the regional database.
For DB2/390 and AS/400 environments, this password is the same as the Privileged User Password, which is the password for Privileged User ID.
Yes
Table Owner/Privileged User ID
t
Logon of the Tableowner on the regional database. It must include privileges to create database objects.
For DB2/390 and AS/400 environments, this logon is the same as the Privileged User ID. This account is a user account that includes the necessary database authority and privileges to create, access, and modify server database objects and native database objects and the operations that are required to implement the Siebel application. These environments include rigid controls on user identification. An account must correspond to a real person.
Yes
Table Space
ts
For DB2/UDB and Oracle installations only. Space on the regional database where tables are created.
No
User Name
u
User name to authenticate the regional database with the Siebel Server of the headquarters node. You can use a database user who is associated with the regional database during the setup, but this user must possess administrator privileges to create logins in the master database, such as SADMIN.
Yes
User Password
p
Password to authenticate the regional database with the Siebel Server of the headquarters node. If you configure the users on the regional database, then Replication Manager uses the password that you specify.
Yes
Siebel Remote and Replication Manager Administration Guide Copyright © 2011, Oracle and/or its affiliates. All rights reserved. Legal Notices.
