Siebel Security Guide > Communications and Data Encryption >
Process of Upgrading Data to a Higher Encryption Level
To upgrade your data to a higher encryption level, perform the following tasks:
- Verify that all requirements are met.
For information, see Requirements for Upgrading to a Higher Encryption Level.
- Make sure that the input file includes every column that you want to upgrade.
For information, see Modifying the Input File.
- Run the Key Database Manager utility to change the password or add a new key to the database.
For information, see Managing the Key File Using the Key Database Manager.
- Upgrade the data to a higher level of encryption.
For information, see Running the Encryption Upgrade Utility.
