Siebel Security Guide > Communications and Data Encryption >
Reencrypting Password Parameters in the Siebns.dat File
This topic provides information on how to reencrypt Gateway Name Server parameters that are encrypted in the siebns.dat file after you have increased the level of encryption you use with Siebel Business Applications. For information on how to increase the encryption level using the Siebel Strong Encryption Pack, see About the Siebel Strong Encryption Pack and Increasing the Encryption Level.
Masked parameters are parameters that have their values encrypted. In the siebns.dat file, parameters that specify password values are masked when they are written to the file. You must reencrypt masked parameters after increasing the encryption level because otherwise the Siebel Server attempts to decrypt the encrypted password using the original encryption key and compares the result to the password entered. If this happens, then the Siebel Server writes an error to the keydbmgr.log log file.
Table 9 lists the parameters that are encrypted in the siebns.dat file that must be reencrypted when you increase the encryption level. Most, but not all, of the masked parameters are Siebel Server parameters that can be changed using the Server Manager program. The following procedure describes how to reset encrypted parameters to use a new encryption level using Server Manager.
To reset encrypted parameters to use a new encryption level using Server Manager
  1. Log in to the Server Manager command-line interface (srvrmgr program). For more information on how to start and use the srvrmgr program, see Siebel System Administration Guide.
  2. Change each of the masked parameters so that it uses the increased encryption level; see Table 9 for a list of the masked parameters.
    For example, enter the following command to reset the Password parameter at the enterprise level:
    change ent param Password=NewPassword
Table 9 lists the parameters that you must reencrypt if you increase the encryption level and indicates how you can reencrypt each parameter .
Table 9. Encrypted Parameters
Parameter
Description
How to Reencrypt the Parameter
ApplicationPassword
This parameter is defined for named subsystems of type InfraSecAdpt_LDAP [the default names are LDAPSecAdpt and ADSISecAdpt].
This parameter is set if LDAP or ADSI security adapter authentication is used.
Siebel Web Clients can use the Server Manager command.
Siebel Mobile Web Clients or Developer Web Clients must edit the appropriate application configuration file.
CRC
CustomSecAdpt_CRC
These parameter are defined for named subsystems of type InfraSecAdpt_DB, InfraSecAdpt_LDAP, or InfraSecAdpt_Custom.
These parameters specify the checksum validation value for the security adapter DLL file and are set for LDAP, ADSI, database, and custom security adapters. For further information on checksum validation, see Configuring Checksum Validation.
CAUTION:  Do not reset or change the value of the DBSecAdpt_CRC parameter. Changing the value of the CRC parameter for the database security adapter can disrupt the correct functioning of your Siebel application.
ClientDBAPwd
This parameter is specified for the Database Extract server component.
Use the Server Manager command.
DSPassword
This parameter is defined for named subsystems of type InfraDataSource (it can be set for the ServerDataSrc named subsystem, or another data source).
It is specified for database security adapter authentication.
DSPrivUserPass
PrivUserPass
These parameters are specified for the Generate Triggers Siebel Server component.
DbaPwd
NewDbaPwd
These parameters are specified for the Generate New Database Siebel Server component used with Siebel Remote.
For information on changing these parameters, see Siebel Remote and Replication Manager Administration Guide.
ExtDBPassword
This parameter provides credentials for the database specified in the external database subsystem.
KeyFilePassword
The key file stores the encryption keys that encrypt and decrypt data. The file is encrypted with the key file password.
Using the Key Database Manager utility. For further information, see Changing the Key File Password.
This parameter is also changed in the eapps.cfg file.
MailPassword
This parameter is set for the email account that Siebel Email Response uses to connect to the SMTP/POP3 or SMTP/IMAP email servers.
For information on this parameter, see the topics on assigning parameter overrides for a communications profile in Siebel Email Administration Guide.
Password
This parameter, set at the Siebel Enterprise level, is the password for the system user (for example, SIEBADMIN) specified by the Username parameter. It is recommended that you do not change the value for this parameter when you reencrypt it.
TableOwnPass
This parameter specifies the password for the Database Table Owner (DBO) account, which is used to modify the Siebel database tables.
Siebel Developer Web Clients must edit the appropriate application configuration file.
Change the parameter in the Siebel database. See Changing the Table Owner Password for instructions.
TrustToken
CustomSecAdpt_TrustToken
These parameters apply in a Web SSO environment only, and are defined for named subsystems of type InfraSecAdpt_LDAP and InfraSecAdpt_Custom.
These parameters are also specified for the SWSE; the setting must be the same on both the SWSE and the security adapter.
Edit the eapps.cfg file for SWSE.
Siebel Security Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
