Siebel Database Upgrade Guide for DB2 for z/OS > Generating the Siebel Upgrade Files > Processing the Index Schema File > Transferring the SCINDX.SQL File to the z/OS HostUse the following procedure to transfer the SCINDX.SQL file generated by the Upgrade Wizard on the midtier up to Pause #3 to the z/OS host. NOTE: Edit the generated files as required by Siebel Technical Notes, Siebel Alerts and Siebel Release Notes on My Oracle Support, or other publications before transferring them to the z/OS host. To transfer the file generated on the midtier
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
