Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > Upgrading Your DB2 SoftwareEnvironments: Development environment only. Before you upgrade, carefully review Siebel System Requirements and Supported Platforms on Oracle Technology Network to verify that you are using the currently supported versions of the following DB2 software:
Make sure that all software meets the requirements specified in Siebel System Requirements and Supported Platforms on Oracle Technology Network. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
