Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > Obtaining Required IBM UtilitiesVerify that the following IBM utilities are available for your upgrade to Siebel CRM 8.1:
For information on these IBM utilities, see your IBM documentation. CAUTION: You can choose to use alternative third-party utility products that are preferred for your environment. Evaluate utilities by individual job. Be aware, however, that if you do use utilities other than those recommended, you might have to modify the SQL supplied with Siebel Business Applications to accord with the rules for those utilities. For help with modifying the SQL supplied with Siebel Business Applications, you must contact your Oracle sales representative for Oracle Advanced Customer Services to request assistance from Oracle's Application Expert Services. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
