Siebel Database Upgrade Guide for DB2 for z/OS > Postupgrade Tasks for Siebel Database and File System > Regenerating the Database Template FileEnvironments: Development environment only. Following the upgrade, you must regenerate the SQL Anywhere database template file used by Siebel Remote. Use the Generate New Database Component from a New Siebel Server option to do this. For procedures on regenerating the SQL Anywhere Template file, refer to Siebel Remote and Replication Manager Administration Guide. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
