Using Siebel Tools > Using Siebel Tools > Process of Setting Up the Development Environment >
Controlling How Siebel Tools Displays the Confirmation Dialog Box
This task is a step in Process of Setting Up the Development Environment.
You can control how Siebel Tools displays the confirmation dialog box.
To control how Siebel Tools displays the confirmation dialog box
  1. In Siebel Tools, choose the View menu, and then click Options.
  2. In the Development Tools Options dialog box, click the General tab.
  3. In the Editing Confirmation Dialogs section, configure Siebel Tools to do one of the following:
    • Display a confirmation dialog box. Add a check mark to a check box.
    • Do not display a confirmation dialog box. Remove a check mark from a check box.
  4. Click OK.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
