Using Siebel Tools > Using Siebel Tools > Process of Setting Up the Development Environment > Resetting Development Tools OptionsThis task is a step in Process of Setting Up the Development Environment. If Siebel Tools behavior is not consistent with the preferences you set, then you can reset them. To reset development tools options
Using Siebel Tools | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
