Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using the Multi Value Property Window
The Multi Value Property Window allows you to view and set values for multi-value properties if you use one of the following designers:
  • Entity Relationship Designer
  • Task Designer
  • Workflow Process Designer
For more information about multi-value properties and how to use the Multi Value Property Window, see Siebel Business Process Framework: Task UI Guide and Siebel Business Process Framework: Workflow Guide.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
