Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars >
Using a New Object Wizard
A new object wizard is a feature you can use that guides you through the steps of creating a new object. It prompts you to configure the properties and objects that Siebel Tools requires according to the object type you are creating. You can use a new object wizard to create the following objects:
  • General object. For example, a business component, table, view, or applet method menu item.
  • Applet object. For example, a list applet, form applet, MVG Applet, or chart applet.
  • EAI object. For example, an integration object.
  • Task object. For example, a task, task applet, task view, or transient business component.
For more information about how to use a wizard for a particular object type, see Configuring Siebel Business Applications.
To use a new object wizard
  1. Do one of the following:
    • Choose the File menu, and then click New Object.
      Siebel Tools displays the New Object Wizards dialog box.
    • Right-click an object in the Object List Editor, and then click New Object Wizards.
      Siebel Tools displays a list of wizards that are specific to the object type you choose.
  2. Choose a wizard.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
