Siebel VB Language Reference > Using Siebel VB > About Data Types > CommentsAn apostrophe precedes a comment. It can occur on a separate line in the code or immediately after a statement or function on the same line. For example: ' This comment is on its own line Dim i as Integer ' This comment is on the code line You can also use a Rem Statement to make a comment. For example: |
Siebel VB Language Reference | Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
