Setting Up Counterparties
This chapter discusses how to set up counterparties.
Click to jump to parent topicDefining Counterparty Information
To define treasury counterparties, use the Treasury Counterparties component (BANK_PNL_TR_GBL).
A counterparty is a bank that has a trading relationship. You must set up the bank before you can define counterparty information.
  1. Define counterparties.
  2. (Optional) Define counterparty address information.
  3. Define settlement instructions for counterparty deals.
Click to jump to top of pageClick to jump to parent topicPages Used to Define Counterparty Information
Page Name
Definition Name
Navigation
Usage
BANK_PNL_TR
Banking, Banks and Branches, Treasury Counterparties
Establish counterparties.
Address Information
BANK_ADDR_PNL_TR
Click Address Information on the Counterparty Information page.
Enter your counterparty's address.
Settlement Instructions
BANK_STL_NET
Click Settlement Instructions on the Counterparty Information page.
Specify, by currency, the counterparty's account into which your payments will be directed as a result of deals transacted with this counterparty.
Click to jump to top of pageClick to jump to parent topicDefining Counterparties
Access the Treasury Counterparties page (Banking, Banks and Branches, Treasury Counterparties).
Most of the fields on this page are the same as the fields on the Bank Information page. We describe only the fields that are unique to this page.
Counterparty Options
Corporate Treasury
Select if a bank is a regional or corporate treasury. This option applies only to internal bank types. Corporate treasury entities have special rights within PeopleSoft Treasury, such as servicing internal accounts. You can designate multiple internal counterparties as a corporate treasury. If you select this check box, you should also specify the general ledger unit with which it is associated. When you select this check box, the system automatically selects the Internal BU check box.
Counterparty Roles
Select the check boxes that reflect the activities in which this counterparty is involved. Options are: Deal Counterparty, Issuer, or Broker.
See Also
Defining Bank Information
Click to jump to top of pageClick to jump to parent topicDefining Settlement Instructions for Counterparty Deals
Access the Settlement Instructions page (click Settlement Instructions on the Counterparty Information page).
You can specify netting options and payment instructions for deals associated with a specified counterparty.
Note. Netting options specified here are used only in the deal settlement netting process; these options are not used in the bilateral account netting process.
See Specifying Instructions for Settling Deals.
Settlement Netting Options
Select a netting option for this counterparty.
Do Not Net
Select if no netting takes place for transactions with this counterparty.
Net
Select if both positive and negative cash flows for each currency are netted, resulting in one net cash flow per currency.
Net Bulk
Select if positive and negative cash flows for each currency are netted separately, resulting in one positive cash flow amount and one negative cash flow amount per currency.
Contractual Netting
If you select either Net or Net Bulk, select this check box to indicate that there is a netting contract in place with this counterparty.
Payment Instructions
Instructions
Select a settlement instruction.
Primary
Select to indicate which instructions are the default instructions in Deal Management.
Settle Thru Internal Account
Select to enable settlements to go through an internal account as opposed to an account in another bank. This check box is available only if the bank type is Internal.
Settle Thru Bank and Settle Thru Account
Select the appropriate bank code and account code.
Payment Method
Payment methods available to you are determined by the selected Settle Thru Bank and Settle Thru Account.
See Defining Payment Methods.
See Setting Up Payment Processing.
Options include:
Automated Clearing House
Direct Debit
Draft - Customer EFT
Draft - Customer Initiated
Draft - Vendor Initiated
Electronic Funds Transfer
Giro-EFT
Giro-Manual
Letter of Credit
Manual Check
System Check
Wire Transfer
Edit Settlement Instructions
Click to access the Beneficiary Bank page and edit settlement instructions.
